Dry carb on '05 wr 450
3 replies to this topic
  • FULTWST
Posted November 24, 2005 - 10:12 AM
I tried to start my wr after months of sitting, nothin. So I drained out the gas in the carb but the carb wont re-fill. I seem to have a good flow from the tank but the carb wont take it in. &%$#@!?
  • Gadsen
Posted November 24, 2005 - 11:02 AM
Setting dry can lead to "oxidation" and things can stick. I suspect you have a needle stuck in the seat or float stuck in the up position. Usually, a small wrap on the lower part of the carb will set it free. But some disassembly may be required.
  • WR450F_RDR
Posted November 24, 2005 - 11:11 AM
the other thing to look at is something simple like an air pocket in the line, try loosening the drain bolt at the bottom of the carb to see if the fuel flows.
  • ARin
Posted November 24, 2005 - 12:13 PM
float stuck?>
