Neutral switch cover plate
2 replies to this topic
  • Scott
Posted December 29, 2000 - 10:04 PM
Through the advise of many on this forum, I installed a Terry Cable neutral switch cover plate some time ago. Looks very cool, fit perfectly, got rid of unnecessary wires...
I noticed yesterday that oil has been leaking from behind this plate. For those of you who are using this product, did you install a gasket or seal along with the plate? One did not come with it and I'm wondering if using the seal from the original neutral switch will work.
99WR,WR timing,throttle stop removed,Uni filter,E-Series pipe,carbon air box,Pro Tapers,lights removed,YZ tank,13 tooth sprocket
  • MotoGreg
Posted December 29, 2000 - 06:34 PM
I seem to remember that it used an o-ring??? I can't remember if I had to use the o-ring from the original switch or if it came with a new one though.
MotoGreg - Posted Image
'92 GSXR 7/11 (Until I get a groovy 996 or GSXR1000)
'99 YZ/WR400F 'cause thumpers rule and two strokes drool!
  • Scott_F
Posted December 29, 2000 - 09:20 PM
You're supposed to reuse the stock o-ring. I just cut off the wires and reuse the stock plastic piece.
