yfz cam in yz cam mod?
4 replies to this topic
  • darksun27
Posted November 23, 2005 - 09:49 AM
i bought a really cheap set of cams off a yzf 450 quad and i was wondering once i get these cams can i do the cam mod (moving the exhaust cam 1 tooth) that the yfz people are doing? by the way i think these cams are from either a 04 or 05 yfz and im putting them into a 2002 yz 426
  • MattFisher
Posted November 25, 2005 - 10:03 AM
The YFZ quad cams are the WR450 cams. Advancing the exhaust will result in the auto-decomression not working. Installing it straight up will result in WR cam timing.
  • darksun27
Posted November 25, 2005 - 12:00 PM
ok thanks
  • darksun27
Posted November 26, 2005 - 09:03 PM
i installed the cams today, the auto decompression wasnt working well. i tried stock, advanced 1 tooth, retarded 1 tooth and it didnt seem to get any better ( it almost felt like you were kicking it over without the decompression cam, it did work a little bit though). are they not working right because these are the quad cams or could it be maybe my clearances arent right? :applause:
  • MattFisher
Posted November 26, 2005 - 11:40 PM
I vaguely remember reading somewhere that the decompression "bump" on the quad cam stuck out a very small amount less than on the dirtbike, but am really not sure.
It's been quite a while since I messed with my friend's YFZ, and I don't remember if there's a way to adjust the decompression release. Possibly someone with more recent and extensive experience will be of more assistance.
The only thing that I can think of at 11:30 at night (past my bedtime ;-) ) is maybe your valves aren't adjusted right, but I'd defer to someone more experienced on that too.
  • Hot  33 replies
  • Hot  79 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
