YZ spark arrestor suggestions please.:-)
13 replies to this topic
  • rdefonce
Posted November 22, 2005 - 10:03 AM
Fellow Yamaha fans,
I've got a '99 YZ400F, with stock exhaust. I've been riding off-road some, so I should get a spark arrestor (for fire prevention, and maybe a little noise reduction!)
Questions: - Is there something that attaches to stock silencer, and if so does it work well?
- If that's not the hot setup, which one would you recommend, that would let me maintain power while running a bit quieter? (preferably one that wouldn't require a boatload of jetting changes!)
Thanks!
Ron DeFonce
  • MotoGoalie
Posted November 22, 2005 - 10:04 AM
I've been real pleased with how well the Q by FMF has worked on my bike. :applause:
  • rdefonce
Posted November 22, 2005 - 12:26 PM
Thanks MotoGoalie, I'll file that under potential candidates!
Did it require much in the way of re-jetting?
Ron
  • Dirty_Sanchez
Posted November 22, 2005 - 12:29 PM
Get a Pro Moto Billet Spark Arrester.
Mine fit up nicely to my stock can and dropped the note down about a db to 98 ish.
Dirty
  • schuon
Posted November 22, 2005 - 12:49 PM
the Q2 is supposed to be better than the original Q series. PMB should also be good, cheaper than a new scilencer. check out this site too, they claim to have straight pipe preformance and quiet it down to 96db and spark arrested.
http://www.purelycus...e-silencer.aspx
  • MotoGoalie
Posted November 22, 2005 - 01:28 PM
Ron
No, not really. I leaned the pj a tad but I'm at high altitude and that prolly has more effect than the pipe.
  • Goosedog
Posted November 22, 2005 - 02:05 PM
Dirty
I second that. :applause:
  • rdefonce
Posted November 23, 2005 - 07:29 AM
Guys, thanks, all this info really helps!
Ron
  • brian389
Posted November 24, 2005 - 06:26 PM
I have a Pro-Moto end-cap on my '04 and it works great, smoothing the power, makes it quieter, and adds no weight.
brian
  • ovrrdrive
Posted November 24, 2005 - 06:37 PM
another satisfied Pro moto Billet user here. It really is the best solution.
  • rdefonce
Posted November 24, 2005 - 07:00 PM
brian
Brian, thanks for the info. That's exactly what I'm looking for.:-)
BTW, we travel to Col. every other year for dirt (or street) biking. I've found that Ouray is a great place to stage out of, since it's got such breath-taking scenery (my wife likes it for jeeping/scenery/shopping) and I go riding.
I've found that in high altitude (between 9k - 13k feet) my bike backfires quite a lot on the downhills . . . hope my slightly larger pilot jet, along with the spark arrestor, helps that a bit.
Ron
  • David37
Posted November 24, 2005 - 11:18 PM
If you like the stock muffler, go with the Pro-Moto Billet end cap w/spark arrester.
  • MotoGoalie
Posted November 25, 2005 - 07:46 AM
Ron
A few of us live a half hour away from Ouray. Look at our jetting specs to cure your backfiring problem at high altitude. I can tell you my bike in the sticky above is jetted perfectly for this altitude.
http://www.thumperta...ad.php?t=248849
Richer is not the answer :applause:
  • rdefonce
Posted November 26, 2005 - 09:20 AM
Pretty cool, living only a half-hour away! . . . you must be in Montrose or nearby?
I reviewed your specs, and I did use the Excel chart the last time I jetted for hi-altitude. My bike was backfiring here (in St. Louis, 500 ft and 75 degrees) almost as bad as hi-altitude. When I went to the one-size-larger pilot (48) the backfiring is mostly gone. (I know that doesn't correlate to high-alt. though, like you said in your post a rich condition can mimic a lean condition.)
One thing's for sure; my 400 won't require the same jets as your 450; curiously the 400 requires generally larger jets than the 450. (Stock jet settings on 450 are smaller than on 400!)
Ron D.
  • 5 replies
  • Hot  33 replies
  • 9 replies
