Gearing Changes
3 replies to this topic
  • halfast
Posted November 19, 2005 - 10:06 PM
I just changed to a 15Tooth Front Sprocket on my WR 426 and I am hearing a noise from the CS Sprocket Area. Have any of you had any trouble with this?
  • Matty05
Posted November 20, 2005 - 01:45 AM
make sure your chain is not hitting the case saver. not much room in there.
Also make sure your cs sprocket nut is done up tight (you might need a friend to stand on the rear brake for you) and the lock washer is bent over right too as you can end up with a mess of oil from the seal behind the cs sprocket.
  • halfast
Posted November 20, 2005 - 01:02 PM
I suspected the chain was slapping the case saver, I just was curious if any one had any kind of catastrophe after going larger on the sprocket.
Posted November 22, 2005 - 09:33 PM
You have to grind away at the case saver a little bit when you run a 15T :applause:
