wr450 motor in 03 YZ450 frame?
13 replies to this topic
  • cb1862003
Posted November 19, 2005 - 03:49 PM
does anyone know if a WR450 motor will fit into a 03 YZ450 frame? i occasionally road race my YZ, and am looking to get some more top speed out of it. the frames have different part #'s, but figure that it may just be some small differences (i hope).
Thanks, Chad.
  • friday
Posted November 19, 2005 - 04:11 PM
save your self the trouble. just buy a pipe or get your head ported
  • sirthumpalot
I believe the WR has a taller 5th gear... actually the 03' YZ only has 4 gears I believe, while the WR has 5.
  • cb1862003
Posted November 19, 2005 - 04:34 PM
correct. i need a taller top gear. i am currently running a 16 front, 38 rear gear set up. i think i am in the 115mph range, but need more. with a swingarm mod, i will be able to get a 35t on the rear, but that woun't be sufficient.
  • Reyndogg
Posted November 19, 2005 - 04:42 PM
wow it seems like it'd be easier to put your YZ suspenders and such on the WR.... or something..
where you running that you need such top end, road america??
  • kawirider
Posted November 19, 2005 - 04:48 PM
You want to go more than 115mph on a dirtbike?! :applause: I could never do that. When I rode my friends YZ250, it had 15 and 48 gearing and tapped out in 5th gear is about as fast as I would ever care to go on a dirtbike. If you want more speed why not just get a 500? I know its not a thumper, but it would definately have all the power you need. There is always the idea of a KTM 525EXC motor. Those have a 6 speed.
  • friday
Posted November 19, 2005 - 05:54 PM
oh 5th gear well that makes sense but i still dont think that would be worth the effort of buying a wr 450 motor and switching it and blah blah but if you really wanna do it and it fits go for it
  • revolucien
Posted November 19, 2005 - 06:02 PM
Doesn't the complete tranny from the WR fit right in the YZ? I think if you look back you'll find a couple threads on it.
  • cb1862003
Posted November 19, 2005 - 07:35 PM
i already have a yz450. i want to built a 490 for it, but it has to be capable of higher top end, thusly, the wide ratio of the WR.
Mid America Motorplex is where i was racing. i was grabbing 4th gear about 100yards out of the last turn, and was looking for another gear by the flag stand. i am guessing that another gear will gain me another 15mph pretty easily. my goal is to run with the top 3 or 4 in the LW class(SV's).
  • cb1862003
Posted November 19, 2005 - 07:39 PM
hmmmm, maybe. i figured the cases where different, so the tranny internals would be too.
i actually want 2 motors for the bike. one for roadracing that is a 5speed and built up a bit. a second that is basically stock and that i use for ice racing, flattracking supermotard and dirtbiking.
Posted November 19, 2005 - 08:12 PM
What you can do for about $700 is to put the complete WR450 transmission into your YZ cases. It bolts straight in, but you need the WHOLE thing, including the shift forks and shift cam.
  • cb1862003
Posted November 20, 2005 - 10:16 AM
Thanks, maybe thats what i'll do then.
  • BC3
Posted November 20, 2005 - 11:02 AM
Be very careful with sustained high rpms with your YZ 450....Thats what killed my cam bearings on mine...(1/4 mile short tracks) Check the clearance at the cam bearing...
BC
  • cb1862003
Posted November 20, 2005 - 11:51 AM
BC
i'll keep an eye on them.
  • 0 replies
  • Hot  50 replies
  • Hot  47 replies
