Floating Ground mod
10 replies to this topic
  • av8shunmeckaneck
Posted November 18, 2005 - 03:44 AM
Has anybody done this mod to their bike? I have done the stator mod and will be recieving the Trail Tech rec/reg in the mail today. I searched and searched but cant find any documentation on how to modify the rest of the wiring in order to install the new rec/regulator. Any tips???? Thanks for help. Steve
  • Birdie426
Posted November 18, 2005 - 10:24 AM
What stator mod are you talking about? I did the floating ground mod a year or so ago on my WR...but I don't remember the details. I do remeber that I was all stressed out about dorkin' up my stator before I started, and when I was done, I thought "That was easy! What was I worried about?". Call Trail Tech Customer Service. That's what I did and they e-mailed me some instructions that were for, I think a YFZ or a Banshee or something, but worked for the WR as well. The folks there were very helpful.
  • av8shunmeckaneck
Posted November 18, 2005 - 01:38 PM
I did the floating ground mod to the Stator already per the Baja Designs instructions
It really was very straight forward and easy. I was able to get the wire out by just removing the clips that hold it in. Much easier and safer than hacking at it with a die grinder.
My question isn't about the mod itself though, but how do I wire in the new recitifier/ regulator? Any suggestions?? Thanks, Steve
  • Asgeir
Posted November 18, 2005 - 02:13 PM
Tell me what you gain from these modifications ???
  • av8shunmeckaneck
Posted November 18, 2005 - 11:14 PM
Alot more charging power. The stock battery charging system puts out just barely enough DC amperage to keep the battery alive. I am doing this modification because I am running an HID light. The stock headlight uses 12vac so I have to do the mod to get more DC Power with enough wattage to run the light. Steve
  • 450high
Posted November 19, 2005 - 02:43 AM
I found the the wiring on there web sit in the tech section under wiring.It shows you how to just unplug 2 plugs under the tand then replug the new plugs in basically.I'm thinking of doing this to charge the battery better while running .I'm trying to under stand why i need to change the light wiring and possibly globes?.Is this because my lights presently are running on a.c from the stator?.
  • av8shunmeckaneck
Posted November 19, 2005 - 02:25 PM
Where did you find the instructions for the wiring? The only instructions I could find were for the KTM.
After you do the floating ground mod to the stator and rewire the harness with the new regulator/rectifier the old headlight wiring wont be connected to anything.
I recieved the Trail Tech reg/rec as planned and it didnt come with any instructions but there is a simple wiring schematic on the side of it that I think will help a bit. Steve
  • 450high
Posted November 19, 2005 - 04:12 PM
Go to there main page then click on - TECHNICAL ASSISTANCE - then WIRRING DIAGRAPHMS - THEN WR 450 RECTIFIER.
Hope this helps.
  • av8shunmeckaneck
Posted November 20, 2005 - 09:20 AM
Hope this helps.
Are we talking about the same website? What site are you talking about 450High? I can't find anything on the trailtech.net site except for info on a KTM conversion. Thanks for any help.
  • av8shunmeckaneck
Posted November 20, 2005 - 09:21 AM
Nevermind. I just went to the BD site and tracked it down just like you said. Sorry, I thought you were talking aboot the Trail Tech site. Thanks.
  • 450high
Posted November 22, 2005 - 02:00 AM
Whoopps didn't relise there was another site.
