Fast Idle on my Wr 426 2002
11 replies to this topic
  • BIGMARK55
Posted November 16, 2005 - 09:36 PM
Help
I have an 02 wr426. It revs like crazy after I close the throttle before dropping back to idle. This is a real nuisance going downhill :applause:
I've been playing with my pilot screw and needle settings and the bike pulls just fine. Just this annoying (dangerous) throttle lag. Will the gray wire mod cure this? What will happen if I disconnect the tps?
Any help would be appreciated.
Thanks
From an old Bultaco rider recently converted. (I really like this WR) :ride:
  • Matty05
Posted November 16, 2005 - 10:46 PM
It sounds like you are lean on the pilot jet. Try winding out the pilot screw a bit more.
Any more than about 3 turns out, go to a bigger pilot jet.
The grey wire mod has nothing to do with this! It apparently advances the timing at full throttle yz style.
tps advances and retards timing regarding throttle position and engine load. Keep it connected.
  • foxomatica
Posted November 16, 2005 - 11:13 PM
Correct, too lean = hanging idle
  • BIGMARK55
Posted November 22, 2005 - 04:53 AM
Thanks for the ideas
I'll let you know if I can cure this with the pilot screw adjustment
  • oldbones
Posted November 22, 2005 - 01:51 PM
Intake leak?
  • lomitamike
Posted November 22, 2005 - 05:33 PM
My 01 does the same thing. I just replaced my needle valve and seat cleaned carb and reinstalled. Now I hit the throttle and it revs high for about 4 to 5 seconds. Going to recheck the boots to make sure their tight (no air leaks).Might be throttle cables also. I,ll check back to see what you find. Good luck. Mike
  • 5valve
Posted November 23, 2005 - 01:04 AM
I corrected my problem, wich was about the same, by cleaning the hot start mechanism..through time, dirt invaded, so it wasnt sealing properly
  • Strattos
Posted December 02, 2005 - 09:17 PM
I have only just developed a similar problem.
I've had my 02 wr426 for more than two years now and its been perfect.
This morning I took it out for the first time in a month or so (its getting warmer here!) and mid way through the two-and-a-half hour ride i'd come to a stop and it would be idling high.
Would the same recommendations as have already been mentioned in this thread hold true if the problem has just started after two years of perfect running?
The strange thing was, if, at idle, I flexed the throttle a little past the normal stop point, it would idle down. But when I revved it again it would settle at est 1000 - 2000 revs higher. The throttle cables don't appear to be catching either, It snaps back nicely when I open the throttle.
  • Rich_in_Orlando
Posted December 03, 2005 - 06:02 AM
I hate to mention this, but check the carb slider for cracks.
  • Drocke
Posted December 05, 2005 - 01:55 PM
I am experiencing the same thing on my 2001 wr 426. I have the pilot adjusted to 2.5 turns. I am thinking it is a dirt problem, because i also drip fuel when i shut down.
  • Drocke
Posted December 05, 2005 - 01:56 PM
how do you clean the hot start system?
  • Strattos
Posted December 06, 2005 - 12:49 AM
I know i'm looking for the easy way out of this, but I've got the carby off. If there are cracks in the slide, should I see them by opening and closing the throttle manually or do I have to dismantle it, which I'm not real confident in doing. For some reason adjusting valve clearances doesn't seem as intimidating as fiddling with the carby.
