WR426 - Winter Storage
6 replies to this topic
  • WR426Frider
Posted November 16, 2005 - 08:56 PM
First winter with this bike and wanted to know what all needs to be to these bikes for storage. It well be sitting for 3 months or a little longer.
  • xcracer123
Posted November 16, 2005 - 09:12 PM
Get some stuuded tires and run it all year around. Winter riding is great!
Otherwise, you should drain the fuel tank and the carb. All the other fliuds should be fine as long as the antifreeze is up to snuff. Change your oil in the spring before you ride and I would also change the break fliud, just for good measure.
  • GCannon
Posted November 17, 2005 - 04:50 PM
Drain the Carb and the Tank. Change the Brake fluid once a year and do regular oil changes you will be good to go.
  • JMathis
Posted November 17, 2005 - 05:01 PM
Why would you park your bike for so long? I live in Ohio as well but I don't think there was a month last winter that I did not ride.
  • Canuck
Posted November 17, 2005 - 05:24 PM
even if not snow-riding, start her up and gun it and down a freshly shovelled driveway once every couple weeks! :ride:
...then look at fredettes studded tires :applause:
  • rich1167
Posted November 17, 2005 - 05:39 PM
Along with draining all the gas. I think if your going to let it sit that long you also need to drop a few drips of oil in the cylinder through the spark plug hole. It's your choice, but I ride all year long.
  • Matty05
Posted November 17, 2005 - 11:15 PM
Yep..... and kick it over a few times with out the spark plug too.
