05 WR Seat
5 replies to this topic
  • Motone82
Posted November 15, 2005 - 09:14 PM
Is the 05 WR the same as an 05 YZ?
  • gl17gl21
Posted November 15, 2005 - 10:00 PM
Yes it is the same seat.
  • Matty05
Posted November 15, 2005 - 10:11 PM
They are different.
  • Motone82
Posted November 15, 2005 - 10:12 PM
SNAP!!!! Will it fit the 03-04 WR with the YZ tank???? Thanks in advance.
  • Dan_Lorenze
Posted November 16, 2005 - 06:29 AM
I pretty sure they're different.....
  • ncmountainman
Posted November 16, 2005 - 08:10 AM
if this helps any, i could not use a 05 yz seat on a 04 wr (even with the yz tank and shrouds) because the subframe was different. so if the 05 wr uses the same subframe as the 05 yz it will not work on a 03-04. :ride: but.....you can grind off the nubs on the subframe(like i did) and it will work then(with yz tank and shrouds). its the 2 nubs that stick up from the rails (the ones the seat locks and rides on) where the back of the airbox is. the yz seat just sits on the rails,and locks in the frame cross piece. :applause: you might be better off just getting the right seat :p
