04 Wr450 Chaingear Recommendation
4 replies to this topic
Posted November 15, 2005 - 06:14 AM
I Am About 50-50 Off Road And Street. Just Looking For A Little Lower Rpm At Like 50 Mph. Stock Set Up Now.
  • Bamster
Posted November 15, 2005 - 07:37 AM
Try a 15 tooth countershart spocket. :applause:
Posted November 15, 2005 - 09:41 AM
Countershart Is That The Front? Also, If I Just Change The Front Do I Have To Change Chain Length Or Rear Sprocket Size???
Posted November 16, 2005 - 01:35 PM
  • JMathis
Posted November 16, 2005 - 01:49 PM
You should not have to change the chain length, you will obviously need to adjust the chain since this will tighten it up but since the stock sprocket is a 14 tooth there is no need to lengthen the chain. You will not need to do anything with the rear sprocket.
