Really stiff clutch
2 replies to this topic
  • kizzle426
Posted November 14, 2005 - 02:44 PM
Is anybody elses clutch insanely hard to pull and engage? The clutch works just dandy but the lever is SUPER hard to pull in. When I first got it, I lubed my clutch cable and that made it only a little easier to pull. Has anybody had this problem as well? Do I need a new cable? The bike is in my sig.
  • bxrjim
Posted November 14, 2005 - 03:41 PM
I took my cable on my 426 and rerouted it by the radiator and followed the frame to take out as much of the turns and bends in the cable as I could. That helps a bit. Then I bought one of those MSR Raptor adjustable clutch levers that have the three different holes you can put the cable in. Now that made a big difference if you know the product I'm talking about.
Try those and lube it again and you'll be happy! :applause:
  • Satch0922
Posted November 14, 2005 - 05:32 PM
two tips...if you do them both....you will have a clutch that is as easy to pull as a YZ125.
First, do the lever mod. It's a easy and fast to do...and CHEAP :applause:
Second, go to Yamaha and buy a clutch actuator arm for a 1998 YZ400F (about $36). Install in on your 426.
And lastly, lube the cable really well.
After doing these mods....you will love it!
Actuator Mod and Lever Mod post on ATM
  • Hot  36 replies
  • 0 replies
Motocross
  • Hot  491 replies
