Need some help with a Wiseco top end.
3 replies to this topic
  • dunecj2a
Posted November 14, 2005 - 09:55 AM
I'm gonna put a new Wiseco piston this week in my 450. I was lookin at today and noticed all the different rings. What order do those rings go in. This is my first 4stroke top end I have done. Man there are alot more rings :applause: What ever happened to 2 rings only :ride:
Do I have to punch the cylinder to Deglaze it like my smokers.
  • Pincushion
Posted November 14, 2005 - 11:51 AM
It should've came with instructions on how the rings go. I believe it went as follows with the piston on the bench and the middle intake indention at 12 o'clock:
-Top end ring between 10 and 11 o'clock
-second ring between 4 and 5 o'clock (exact opposite from top end ring)
-oil ring gap goes in the same place as the top end ring (between 10 & 11 o'clock). Make sure the ends do not overlap each other, they must butt up end-to-end. Next insert the upper oil ring and put the gap betwen 6 and 7 o'clock. Finally insert the lower oil ring (making an oil ring sandwich) and the gap goes in the same spot as the 2nd ring (between 4 & 5 o'clock).
its much easier to see on paper. Make a diagram if necessary so you can see it.
  • dunecj2a
Posted November 14, 2005 - 01:29 PM
Thanx Pin, Will my OEM look the same? Will it have those different rings that the wiseco has?
How about punchin the cylinder?......thanx :applause:
  • Pincushion
Posted November 14, 2005 - 01:50 PM
OEM rings are the same also. here's a PDF to the manual, look around section 4-44 for piston/ring info
Read the replies to this thread about honing the cylider
http://www.thumperta...ght=cross hatch
If you bore it then you've got to have the nikasil reapplied, which is no small feat. But if its good shape then just do what Grayracer says.
  • 5 replies
  • Hot  33 replies
  • 0 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
