Bolt that holds the baffle in
2 replies to this topic
  • dbailey223
Posted November 12, 2005 - 07:51 AM
As fate would have it, I go on a bike ride the day after ordering a PMB insert and the stock baffle starts rattling all about. I check it and it is extending out about 1" from the pipe. I tried to remove the bolt to just yank the sucker out, but the bolt appears stripped or something--it just turns and turns.
I assume that it is just a bolt and that the threads on it or the pipe are screwed up. Am I on the right track? ANd if it is the pipe screws that are messed up, is there a fix or do I need a new pipe?
  • Rich_in_Orlando
Posted November 12, 2005 - 10:10 AM
I use a longer bolt on the baffle and a self-locking nut on the end of it just to be safe. Otherwise, it likes to loosen up. I lost a baffle earlier this year because the bolt vibrated out. I check it more frequently now.
  • dbailey223
Posted November 12, 2005 - 02:17 PM
Turns out the bolt was spinning because the baffle broke where the bolt screws into it. So, my pipe is fine. My PMB insert should be here soon!
