headlight dosent work
9 replies to this topic
  • billbanshee
Posted November 11, 2005 - 05:11 PM
just got the bike 01wr426 headlight didnt work when i got it figured the bulb was probably just busted but it looks perfectly fine to me any suggestions on what to do next?thanks in advance
  • ARin
Posted November 11, 2005 - 05:40 PM
check your connections and switch for shorts.
and no matter what the bulb looks like, it still may be fried...try a new bulb.
  • billbanshee
Posted November 11, 2005 - 05:43 PM
i assume you have to get them from the dealer?
  • ARin
Posted November 11, 2005 - 05:50 PM
no...see what kind of bulb it is, and get it from an autoparts store or walmart.
the 450's use an h4 bulb, not sure about yours.
  • billbanshee
Posted November 12, 2005 - 03:41 PM
replaced the bulb still nothing :applause: how do check for a faulty switch?
  • ARin
Posted November 12, 2005 - 04:15 PM
voltage meter.
  • gregwr450f
Posted November 12, 2005 - 06:21 PM
Check your wires aren't crushed between the steering stops, that's what happened to mine.
  • billbanshee
Posted November 12, 2005 - 10:52 PM
if i connect the two wires it should work unless i have a broken wire right?
  • billbanshee
Posted November 14, 2005 - 01:18 PM
checked all connections everything looks good i dont have a voltage meter what should i do now? this is killing me since it gets dark so early now
  • billbanshee
Posted November 14, 2005 - 01:19 PM
btw i dont have a taillight if that makes any difference
