Air filter oil (both sides or just one
7 replies to this topic
  • jkwithers
Posted November 11, 2005 - 05:02 PM
:applause: :ride: Do you oil both sides or just the side panel side thanks :p
  • onaXR
Posted November 11, 2005 - 06:01 PM
Oil the whole thing -outside then squeeze it in and blot with a towel.
  • BWB63
Posted November 11, 2005 - 06:18 PM
Don't use spray on........
Like it was said, squeeze out the extra oil and that is the right amount.
You can wash a used filter over and over again and once you think it's done wash it in a clean bucket with gas and you will see how much more dirt comes out. A lot. I use Golden spectro foam filter oil. It's messy and water proof.
  • bootlegger2
Posted November 12, 2005 - 05:06 AM
i think you need to clean it often that is for sure ,i found that the k&n filter cleaner works rather well to clean it i hate use gas seems to shorten the life of the filter ,i also use some dishwashing liquid to help also ,but the gas well definitly bring out all the funk, i use just the belray stuff and the regular way to oil it and ring out and good to go, i found i think that the stock filter are better than the aftermarket and last a little longer but they cost a little more but you get what you pay for.
  • goblin127
Posted November 12, 2005 - 06:46 AM
Why should you not use spray on filter oil?
  • BWB63
Posted November 12, 2005 - 08:30 AM
It costs more in the long run. Hard to get enough to saturate, not as sticky. Most get dust through there filter using spray on.
  • goblin127
Posted November 12, 2005 - 09:36 AM
Oh I was trying to use up some K&N that ive had around the house and I have been going real lie with it . I better change tachtics.
  • jkwithers
Posted November 12, 2005 - 06:30 PM
Thanks for your help
  • 3 replies
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
  • 17 replies
