Radiator Fins
3 replies to this topic
  • WR426Frider
Posted November 09, 2005 - 05:35 PM
Is there a need for the white fins that are in front of the radiator. Wouldn't they hold back air flow?
  • Johnny34
Posted November 09, 2005 - 06:19 PM
You're serious, right?
The plastic covers are for protection only. They're supposed to deflect small debris and low flying aircraft from slamming into your radiators. Get some Devol guards (or other) if you're concerned about protecting your radiators. If you want more airflow, I suggest fabricating some big air scoops that mount on your helmet and channel the air down your shirt sleeves, bounce off the back of your handguards and into the radiators. Talk about ram-air induction! :applause: You would be the coolest racer at the track. :ride: :p
  • SJMC_DON
Posted November 09, 2005 - 10:37 PM
The plastic covers are for protection only. They're supposed to deflect small debris and low flying aircraft from slamming into your radiators. Get some Devol guards (or other) if you're concerned about protecting your radiators. If you want more airflow, I suggest fabricating some big air scoops that mount on your helmet and channel the air down your shirt sleeves, bounce off the back of your handguards and into the radiators. Talk about ram-air induction! :ride: You would be the coolest racer at the track. :p :p
Smart a$$ :lol: :p :p Actually they do help funnel air across the radiator but you are better off running the Devol guards but the stock fins ARE BETTER THAN NOTHING, do not just take them off without replacing them with a suitable guard, (flatland, Devol, unabiker, etc....) :applause:
  • ARin
Posted November 09, 2005 - 10:39 PM
The louvres also direct the airflow more efficiently across the rads...
I believe a TT member once did a temp study, and the rads were more efficient WITH the louvres than without.
