Want to 86 the ignition
8 replies to this topic
  • snmhanson
Posted November 08, 2005 - 08:03 PM
I just put a YZ number plate on my 05' WR450 and now I have my ignition switch hanging over the handle bars. I have done a search and found talk about getting rid of it but nothing from anyone who has actually done it. Anyone know what will happen if I take it out and how to do it? I can pull the wire from the harness no problem and I assume I would just need to splice two wires together to bypass the switch. Or maybe there's a better way to do it? Also, if the ignition is always on as it would be in this case is there too much draw from the battery? Thanks.
Matt
  • RADRick
Posted November 08, 2005 - 10:18 PM
Here's how I did mine.
http://photobucket.c...nt=WR2YZ004.jpg
I used the start/run/stop switch from a TTR-250 and moved the on indicator light to a bracket I fabbed for my TrailTech computer that slides under the handlebar clamp.
http://photobucket.c...nt=WR2YZ003.jpg
The wiring is pretty easy if you can read a wiring diagram.
  • snmhanson
Posted November 08, 2005 - 10:50 PM
Looks pretty trick. I can't read a wiring diagram but I'll do it anyway. I just bought a TrailTech today as well so I think I'll try to do something identical to what you did unless someone can tell me how to do away with it all together. Thanks.
Matt
  • Brettv
Posted November 08, 2005 - 11:30 PM
DUUUDE, &%$#@! did you do to your leg???????
  • ncmountainman
Posted November 09, 2005 - 05:54 AM
a psychotic fan hobbled him,and locked him up with a typewriter to write a novel :ride: no thats some serious hardware,i've got a small plate in my left fibia....i can't imagine that sort of pain :p hope ya heal well :applause: hey i see you have "hurricane" clamps,i used them before i changed my offset and thought they were awesome :p
  • gmoss357
Posted November 09, 2005 - 06:23 AM
Check out my mount in my Garage. A piece of aluminum will work also. I have never hit it and it's an easy install.
  • RADRick
Posted November 09, 2005 - 04:51 PM
Thankfully, it was a work-related injury. :p
Now that the weather is changing I need a leg warmer or I get chills. I'm doing OK, though. The fractured calcaneus on the other leg is worse.
Magazine-guy freebie. I like them, but they are a bit on the heavy side. They do keep the vibes to a minimum with the isolators, though, and I like the flip-around adjustment. I have another set but I have no idea what they fit. :lol:
  • SpeedBlitz
Posted November 10, 2005 - 06:42 AM
Thankfully, it was a work-related injury. :applause:
If you don't mind me asking, "work-related" as in bailing out mid-air during a bike test?
I hope the recovery goes well. Good Luck.
  • RADRick
Posted November 10, 2005 - 02:20 PM
Bailing out mid-air? Damn, I wish I would have thought of that! :ride:
Thanks! :applause:
