Boysen Quick Shot And Power Now Questions???
10 replies to this topic
  • bandit99
Posted November 08, 2005 - 12:14 PM
Has anyone put these on their WR450 and are they worth the money?
  • Math
Posted November 08, 2005 - 12:18 PM
If I recall right, there has been abundant discussions about that in the past in the WR4xx forum. Use the search tool, I'm sure you'll be pleased with what you find. :banghead:
  • clark4131
Posted November 08, 2005 - 12:47 PM
I have both and I could take 'em or leave 'em. Of the two, I could feel a tiny difference with the PowerNow..SC
  • Atlasrider
Posted November 08, 2005 - 08:10 PM
I have neither, try changing your leak jets and using INDYS jetting chart in conjunction with a JD jet kit :applause:
  • bandit99
Posted November 09, 2005 - 07:51 AM
I have the JD jet kit and get a low end bog. I never changed the leak jet though. What size is stock? I see that most people are using a #40 for the leak?
  • vmxr
Posted November 09, 2005 - 07:53 AM
I have one and it made so little difference that I took it back off and was going to sell it. That was with the stock exhaust.
After going to a full FMF Powerbomb/Q system, I rejetted, made sure the pump was adjusted corectly, did the leak jet mod and still had a bog at low RPM. So I put the quick shot back on and it cured the bog. Runs sweet now!
YMMV
  • Indy_WR450
Posted November 09, 2005 - 07:47 PM
Dont forget that you can plug the stock leak jet for better results in winter riding weather. :applause:
  • wayneoXCF
Posted November 13, 2005 - 04:11 PM
$90 seems like alot for a minimal increase in response. I did the BK and rejetted, have no bog- so I think I'll save my cash.
  • Timbo2
Posted November 13, 2005 - 05:52 PM
Hey guys, I have a 2004 wr450f that is almost new. The battery is locked up and wont take a charge, the starter just clicks quickly. I jumped it with my truck and the started turns right over. should I keep my battery tender on for weeks at a time even though I'm riding often?
  • clark4131
Posted November 13, 2005 - 06:14 PM
Maybe you should install a Quickshot and then think about a Power Now...Or did you intend to hijack this thread with something completely off topic?...Was that over the top? I can never tell :applause: ...SC
  • bg10459
Posted November 13, 2005 - 07:33 PM
SC, as you are usually over the top, that wasn't such a ridiculous question. But in this case you were spot on. :ride:
I'd suggest new bars and then an exhaust. Newb's :applause: I was one once too.
