Low Mount Steering dampener question
7 replies to this topic
  • jkwithers
Posted November 07, 2005 - 01:15 PM
Yes yet another damn dampener question. Has anybody bought and used the low mount dampener that mounts to the fron fender? I have been considering one. I like it opposed to the upper triple clamp mounted version because I heard that you either have to remove it or install a sight tube to check your oil. But I also heard that you cannot adjust it on the fly. what are the pros and cons. Also if you are riding desert do you really need to adjust it often? Your input is much appreciated.... :banghead:
  • kehale
Posted November 07, 2005 - 02:22 PM
I have the SUB mount.
It mounts beneath the bars, between the triple clamp.
it can be seen at:
http://www.brpit.com...mount_info.html
it's quite nice.
The only thing is that since the mounting arm is longer, you will need to dial in a little more dampening.
I run mine at 7 clicks out (slow speed)
-T
  • roadcam
Posted November 07, 2005 - 02:28 PM
sounds like you're describing the W.E.R. (Works Endurance Rider) damper ... cant tell you much about it, except that it seems to find more favor with eastern enduro-type riders, while the western riders pretty much favor the SCOTTS .. not sure why that seems to be the case .. :banghead:
  • BWB63
Posted November 07, 2005 - 04:44 PM
I have tried the W.E.R. and did not like it. It seemed to have to much free play in the center. Has to do with the linkage. You can adjust it on the fly if you jump high enough reach over the bars, do a fender grab and on the way back make a quik adjustment :banghead: :banghead:
  • Countdown
Posted November 07, 2005 - 05:06 PM
I have the WER on my XR400 & XR600. The 600 is a death trap without it.
Free play at center is sign you have air in it. No play if every lthing adjusted properly. Easy to add fluid but cause was probably leaking aroung the shaft.
  • BWB63
Posted November 07, 2005 - 05:16 PM
I have tried the RTT it was cool but, it started leeking even after the factory fixed it. Scotts has no play and has a cool fast speed valve, GPR is real nice but, the W.E.R. is different with that linkage. It does not have the same resistance through the stroke as the others. The linkage just got sloppy after time. It's just not the same as the others.
  • loufish
Posted November 08, 2005 - 06:55 PM
I run the Scotts with real nice billet machined pin mount. This pin is foreward of triple clamps, and I have no problem accessing the dipstick.
I've hit a couple of rocks that I'm sure would have thrown me if not for the Scotts Hi-speed damping circut...
  • XR4DEZ
Posted November 08, 2005 - 07:47 PM
Scotts has a bottom mount available now, for the guys that don't want anything in the way on the bars. WER is a speed sensative unit that kicks in with sharp hits. The Scotts unit works in the high speed mode and with low speed damping so you have a lot more adjustment. I have'nt tried the GPR set up.
  • 2 replies
Washington
  • Hot  32 replies
  • 17 replies
  • 3 replies
  • Hot  148 replies
