such thing as an off-idle RICH bog?
5 replies to this topic
  • ARin
Posted November 06, 2005 - 11:06 PM
i recently switched to a 40 leak jet, and boyeson quickshot, which did very little for my off-idle bog.
if i wick real quick off of idle, it will bog hard. is this condition ALWAYS a lean condition?? do i need to solder my leak jet shut for a richer squirt??
  • bg10459
Posted November 07, 2005 - 05:57 AM
Can't say for sure, but when I was jetting, I tried a 40, 52 (50 not available at the time, but not much difference anyway) and the stock 70 in various combinations with 42, 45 and 48 pilot jets. I found the best results with the 52 leak jet and the 48 pilot (sea level, 80 - 90, high humidity), even though most guys use and recommended the 40 lj. I too added the quick shot (but only after the jetting was as good as I could get it), which I feel made a slight improvement.
  • StreetbikePimp
Posted November 07, 2005 - 09:49 AM
If the bike bogs...stumbles/stutters...and goes without stalling, then I would say that the bike is slightly rich.
But...I'm still trying to get rid of the bog on my bike....
  • clark4131
Posted November 07, 2005 - 05:51 PM
Have you tried adjusting your AP squirt? CW delays it, CCW lengthens it provided it's not hitting the slide too early...SC
  • ARin
Posted November 07, 2005 - 06:41 PM
I originally set it to the recommened setting with the gapper tool provided with the quickshot.
I think im gonna go back and set it according to the slide.
  • clark4131
Posted November 07, 2005 - 07:00 PM
With the cold weather hitting us, I popped in a #45 leak and turned my AP screw 1/2 turn CW. I haven't ridden it yet, except for a quick turn around the block, but it seemed to like it...SC
