Wr450 Throttle Stop Swap
3 replies to this topic
  • JETMAGNUM
Posted November 06, 2005 - 07:47 AM
Removal Of Carb Necessary?
  • ARin
Posted November 06, 2005 - 08:51 AM
no.
it makes it easier however if you loosen the boots and at least turn the carb. and removing the rectifier (03-04) or the AIS air pump (05-06) makes it a good bit easier.
  • byggd
Posted November 06, 2005 - 09:59 AM
Here is a link for the 03 but all have the same screw location. Not sure if the coil is in the same location as my 02 426 but I can remove my screw once the coil is out of the way without turning the carb :banghead:
http://www.off-road....4/runright.html
  • JETMAGNUM
Posted November 06, 2005 - 10:03 AM
this is a 2004 wr
