MDSmith said:
Your last photo looks like you just bolted the swing arm assy from the RM to the DRZ but that is not the case.
That is, indeed, not the case. I was just trying an initial fit up. Here is more of the story on the swingarm.
Here is the first problem: the DR-Z swingarm bolt is bigger in diameter than the RM swingarm bolt. That is the DR-Z on top.
That means that the bearings on the RM swingarm are too small for the DR-Z bolt to go through. Either the RM swingarm mounts need to be made larger, or the DR-Z frame and engine mounts need to be made smaller. Also, the RM bolt is too short. So, rather than trying to make the DR-Z mount points smaller (which is pretty tough, given that they are holes), I chose to make the RM swingarm mounts larger.
I took the swingarm to a local machine shop and had them bore out the mounts so that they would accept the DR-Z bushings. Here is a picture after boring.
One thing I do not like is that the RM swing arm has bearings, while the DR-Z has bushings. Bearings are a better mount than bushings. But, sometimes you have to put up with tradeoffs in these projects. I decided to, at least, replace the bushings with new ones. I ordered an All Balls set. And what do you know... when it showed up it was bearings. Here is a picture of an original bushing and a new bearing.
I just pressed the DR-Z bearings into place in the machined RM swingarm using a vise and sockets, and here is the result. (The bearings still have some foam packing in them.)
Here is the RM swingarm mounted in the DR-Z.
I am using the shock linkage from the DR-Z.
So... here's what the RM swingarm looks like mounted on the DR-Z. This is not the final mounting, because I need to do a little welding to mount the rear master cylinder and I don't want the swingarm in place when I do that.
Another part of this project is engine upgrades. That is not essential when making these suspension changes, but it seems a bit of a waste of good suspension to not do them. Here is the engine without the head and cylinder.
