120 rear tire on YZ 426?
10 replies to this topic
  • inte
Posted November 03, 2005 - 03:38 PM
I've got a bone-stock 2002 YZ-426 & am wondering if a 120/90-19 rear tire will fit without rubbing, or having to move the wheel so far back the chain gets too tight.
Anyone run a 120 on their stock 19" rim?
  • SBRacing
Posted November 03, 2005 - 04:26 PM
i have one on my 450 im sure it will fit fine....
Posted November 03, 2005 - 04:54 PM
Some may rub, most won't. My 120/90 Maxxis IT clears everything.
  • Satch0922
Posted November 03, 2005 - 05:19 PM
because the thumpers "hook up" anyway, all your getting with a bigger tire is more weight. I have tried them both and would not run a 120 on a thumper again.
Having said that....I have a 120 on my 05 smoker ! :banghead:
  • FZ1426
Posted November 03, 2005 - 05:20 PM
I've got a nice 120 sitting here but I can't bring myself to do anything that would increase the weight of the (already heavy) 426. Why put on a 120?
Yes, I'm nit picking...
  • Hick
Posted November 03, 2005 - 05:33 PM
Why put on a 120?
Sand. Sand, sand, sand, sand.
Sand is all I ride in, 120s are all I run.
So I know that a Dunlop 120/90/19 will not (noticeably) rub anything on a 426.
  • SBRacing
Posted November 03, 2005 - 06:13 PM
I will not run a 120 again..for all the same reasons my 120 was a hand out thats why I used it...
  • 642MX
Posted November 03, 2005 - 07:42 PM
I ran a 120 Maxxis and it cleared just fine. Like the others said, there really is no good reason to run that big of a tire.
Posted November 03, 2005 - 08:02 PM
Works Fine, I had one on my 02 426, lot "O" meat! :banghead:
  • inte
Posted November 03, 2005 - 11:19 PM
Thanks for all the replies - I've been running the stock 110-90/19 on there, on my 2nd one now with no problems. Only reason for considering the 120 is at the behest of some guys I'll be riding with in Baja - they contend that having the larger sidewall profile is important to prevent damage to the rim in rocky stuff.
I figure I'll just keep a minimum of 15 psi in the stock 110 & it should be fine...?
  • Satch0922
Posted November 06, 2005 - 06:17 AM
:banghead: :banghead:
