wr reliability with yz timing
4 replies to this topic
  • poffer
Posted November 02, 2005 - 03:52 AM
Just wondering if my wr engine will last shorter if I change the stock exhaust cam to the on from a yz450f and how reliability would be???
Have heard some that had blown engine on high rpm (piston meets valves)...?
  • Matty05
Posted November 02, 2005 - 04:10 AM
as long as proper shims are used, reliability shouldn't change.
A lighter flywheel might work too instead of YZ cams.
  • poffer
Posted November 02, 2005 - 07:33 AM
What do you meen about proper shims??
  • vmxr
Posted November 02, 2005 - 07:50 AM
Sounds to me like somebody didn't get the correct timing set on the YZ cam.
  • simon@vic
Posted November 02, 2005 - 08:22 AM
reliability will remain exactly the same. and no you don't need a lighter flywheel!
as in you have to adjust the valves when you change the cam.
