04 YZ450F 4 speed?
8 replies to this topic
  • timpoke
Posted November 01, 2005 - 08:35 PM
Are the 04 YZ450F's 4 speeds or 5 speeds?
Posted November 01, 2005 - 08:42 PM
the '03-'05 models are four speeds. When geared so that first on both bikes is the same overall ratio, there is a 3-4 mph theoretical difference in the top speed of the YZ450 and the YZ426 with a 5 speed. The four speed just means that you have to shift less often.
  • mose29
Posted November 02, 2005 - 04:49 PM
I was told that the first gear was taken out.
  • sjwr450
Posted November 02, 2005 - 08:16 PM
The other gears are spaced a bit, but first gear is tall.
  • Jetsprint2
Posted November 03, 2005 - 12:59 AM
I really like the 4 speed on my 04', I race and trail ride with a stock flywheel. I don't stall in the tight stuff unless I go down. Just used to it I guess.
  • Dirty_Sanchez
Posted November 03, 2005 - 03:34 AM
4 Gears to choose from is plenty for me as well.
Tight twisty's in the woods after dropping 1 tooth on the front is perfect in 2nd or 3rd. I rarely have to drop into 1st in the woods. 3rd is perfect all the way around for playing on the tracks I frequent-never have to shift. Stock Flywheel as well with a Rekluse.
Dirty
  • ride yzf all the way
Posted November 03, 2005 - 05:17 AM
04 yz450f is a 4 speed
  • ncmountainman
Posted November 03, 2005 - 05:41 AM
Dirty
i'm with you sanchez, the 4spd with a rekluse is a woods weapon :banghead: i'm much faster on the same trails compared to my wr :banghead:
Posted November 03, 2005 - 09:39 AM
Nothing was "taken out". The 4 speed is a totally different transmission from the 5 speed. The WR450 five speed will interchange as a complete unit, but none of the parts from one transmission will fit the other.
First gear in the 4 spd is 1.93
First gear is YZ426 is 1.85
4th gear in the 4 spd is 1.05, which splits in between the 426's 4th and 5th, which are 1.09, and .95
Mine is geared (15/49) so that the overall ratio in 4th is identical to the overall ratio of a stock YZ426 in 5th, and that gives me a first gear at 17.76, instead of the 18.68 of the 426. A little taller, but not bad, usually.
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • 9 replies
  • 10 replies
