Zip Ty Racing
6 replies to this topic
  • Tsk350
Posted October 31, 2005 - 11:30 PM
Quick question. I am about to make an order from ZIP TY and was curious what I should get from them for my 2003 WR That is in the process of a 95% rebuild. It only has 80 miles on it and other than free mods it is completly stock. :banghead:
  • Indy_WR450
Posted November 01, 2005 - 02:05 AM
I recommend the following from Zip-TY:
Fuel screw
Magnetic drain plug
TM Designs chain slider
TM Designs chain guide
Neutral switch replacement cover
Left side front wheel spacer from YZ kit ( no more seal grooves cut thru stock soft spacer)
  • clark4131
Posted November 01, 2005 - 07:40 AM
Don't forget the Zip-Ty Hot Start nut! Also, their axle block setup is pretty trick, but not a necessity...SC
  • dbailey223
Posted November 01, 2005 - 09:33 AM
And get a shipping quote over the phone otherwise you won't know the amount if you order via web, despite a webpage confirmation and email from them that will both say $0.00 for shipping.
  • The_Blue_One
Posted November 01, 2005 - 10:53 AM
Call the TT store and order it. If you order everything listed shipping will be free :banghead:
I'll second the hot start nut and blocks. They aren't a necessity but they are nice :banghead:
  • Indy_WR450
Posted November 01, 2005 - 11:00 AM
Yeah I forgot about the red aluminum nut for the hot start cable connection to the carb. It is a must! :banghead:
  • Tsk350
Posted November 02, 2005 - 12:38 AM
Thanks for all the help I am going to place my order asap!! Thanks :banghead:
