Different Renthal Sizes??????
9 replies to this topic
  • hybridz77
Posted October 31, 2005 - 10:19 AM
Yeah I am going to pick up some of Renthals Twinwall Handlebars but I really have no clue as to what the differences are between their sizes
They have McGrath, Carmichael, CR High, Emig, and Windham
Anyone have any suggestions, I am 5'8" (lil small for wr450) BUT still lovin this MEAN ASS ride.
  • ARin
Posted October 31, 2005 - 11:08 AM
If you click on the "applications" button on this page, it will give you dimensions of the different styles.
http://www.renthal.com/twinwall.asp
  • rushfan
Posted November 01, 2005 - 06:48 AM
I happen to like the bend of the stock Renthal bars on my 05. I just want to up grade to either Renthal twin wall or Pro Taper fat bars. I haven't made up my mind as to which ones I want, but I am not that picky about the bend. The current bend is just fine. :banghead:
  • hybridz77
Posted November 01, 2005 - 10:41 AM
With the Twinwall Bar is the inner diameter a factor to consider when ordering Barkbusters (handgaurds), Moose's product imparticular. They list three sizes Magura/KTM, Flex series/Pro Series/Fatbar, and 7/8. I believe the fatbar size is what would be needed, is this correct?
  • bg10459
Posted November 01, 2005 - 03:58 PM
Can't say for sure, but when I asked about the Pro Taper mount kit for my acerbis guards, I was told they will not work with the Twinwalls.
  • Matty05
Posted November 01, 2005 - 06:18 PM
If I were you, I would just wait untill you bend the stocko's.
It won't take much to bend them.
  • rushfan
Posted November 01, 2005 - 07:18 PM
Really? Are the stock Renthals that weak?
  • Matty05
Posted November 02, 2005 - 03:27 AM
My missus bent hers just by dropping her bike, I bent mine by washing out in a corner.
Just a slight bend in your bars can really throw off your riding. I got new bars and kept the old ones for spares.
  • hybridz77
Posted November 02, 2005 - 08:17 AM
Yeah I Looked At The Posted Link To Renthal And Found That The Outter Portion Is 7/8 So More Common 7/8 Barkbusters And Controls Can Be Used. But The Diameter At Bar Mounts Is 1 1/8 So I Guess Its Like A Pro Taper Bar But Not Tapered Just Stepped Instead!!
  • bg10459
Posted November 02, 2005 - 12:38 PM
Only problem is, the hand guard mounts on the end fit inside the end of the bar. I'm pretty sure the Twinwalls have a thicker wall than the 7/8 bars (smaller I.D.) The O.D. is 7/8 at the end so your controls and grips will fit.
