Handle Bars ?????
9 replies to this topic
  • WRFUN
Posted August 22, 2001 - 03:36 PM
I'm 6'3" 220lbs and need more room. My knees hit the H-Bars when cornering. Any recommendations on bars, top clamp, or both. Thanks for your help. ( Love this bike )
99 WR400
lid off
uncorked stock pipe
restricter screw cut
  • Bill
Posted August 22, 2001 - 04:24 PM
Here's a couple of suggestions. For bars,the Renthal Jimmy Button highs are the popular choice and for a cheap TC alternative. Find a used TC from a 2000 or later bike. The bar mounts have been moved 10mms forward.
Bill
99 WR400f, YZ timed, MX-Tech suspension, Scotts steering damper, White Bros E-Series (12 discs), tapered header and a/f. Kouba T-handle for the fuel screw. Works Connection billet throttle tube and frame guards. Cycra Pro-Bend, triple clamp mount handguards. Thumper Racing rad guards, Renthal Jimmy Button highs, YZ Tank and IMS seat, YZ number plate, odo removed, EKP #4, 50PJ, 175MJ at 500-1000' Thanks James Dean!
  • WRFUN
Posted August 22, 2001 - 04:43 PM
Thanks Bill, I see you have alot of mods done to your bike. Any suggestions on what would be the next best for me (performance).
Thanks,
Pete
  • Bill
Posted August 23, 2001 - 04:30 AM
WR,
I would go to YZ timing and the jetting (if your below 3000') I have listed. While doing this, you probably want to find a used YZ pipe. I wouldn't spend the money on an aftermarket pipe, unitl they build a quieter pipe. YZ pipes can be found for around $100 or you might be able to trade a YZ guy looking to quiet his bike down. I'll assume since your bike is a 99, that someone has already upgraded the air filter??
For other mods, here are my thoughts:
Tires- 739's suck, Dunlop 755 or 756
Damper- great for reducing deflection, awesome in the woods and great on the track. Also reduces rider fatuige.
YZ Style seat and tank- big improvement in the corners, allows you to better weight the front end by moving further forward
Thumper or Flat Land rad guards- heaviest duty made, a lot cheaper then radiator repair
YZ Style- If you don't ride at night or need to keep track of miles. You can save a lot of weight by going to a YZ front number plate (you'll have to buy the YZ axle spacer and seal, also make a little bracket to mount the plate) Lighter rear fender.
Triple clamp mount handguards- keeps me safe when I bonk a tree :D, saves levers, strengthens/protects my Renthals and keeps roost and mud off.
MX-Tech suspenders- Bikes is plusher, yet handles big jumps better. The forks have a much more linear travel and when I come up short on a double :) the bike is much more forgiving. AWESOME customer service.
Bill
[This message has been edited by Bill (edited 08-23-2001).]
  • WRFUN
Posted August 24, 2001 - 04:09 PM
Bill, took your advise and ordered the Jimmy Buttons. Thanks for your help!!!!!!!!!!
Pete
  • freestyle111
Posted August 24, 2001 - 07:49 PM
go all the way berg tripleclamp with some renthal twinwall[cr hi bend]
  • YAMAKAZE
Posted August 26, 2001 - 12:33 PM
I bought the new Renthal Fat Bars $89. and a set of universal adapters $44. this weekend...up 1 inch on the mount and 3 inches on the bend...Man what a difference. :) I was going to buy the buttons but opted for the double wall hoping that this will be the last pair fo a while...Man what an open cockpit. :D
Bonzai... :D
  • WRFUN
Posted August 27, 2001 - 11:42 AM
Yamakaze,
Thanks for your input, I will keep this in mind if the Buttons don't seem for me. Have fun on the trails !!!!
Thanks,
Pete
  • Tim_Heslip
Posted August 27, 2001 - 04:32 PM
Pete,
Where did you get he Button Bars? Local or internet? What is the cost? I may be in the market for bars soon. Thanks.
Tim Heslip
  • WRFUN
Posted August 28, 2001 - 09:22 PM
Tim,
Chaparral has them in stock. Should get them this week, can't wait.
Later,
Pete
