Moose Tubes
21 replies to this topic
  • NJONES
Posted October 26, 2005 - 11:29 AM
Hello Everyone,
I'm looking for input on running the solid moose tubes. Has anyone done this? Do you like or dilike and what should I be aware of or expect.
Thanks
  • simon@vic
Posted October 26, 2005 - 03:23 PM
i would not bother, bad idea imho.
just run good quality HD tubes @ 14psi front and 12psi rr.
  • Matty05
Posted October 26, 2005 - 04:26 PM
You need a special tyre fitting press to get the tyre on the rim.
Moose tubes won't go flat but cost more than the tyre that it is in. They are a lot heavier too.
I guess everyone here is running heavy duty tubes, including me. If you are worried about punctures, you can add some of that tyre weld stuff into your tube.
  • ibleedblu
Posted October 26, 2005 - 05:58 PM
I know a guy here in Las Vegas that used them in desert races so they wuoldn't have to worry about getting flats, but he claimed thats all there good for. Just like Matty05 said they are heavy, And tires don't last half as long
  • rushfan
Posted October 26, 2005 - 06:30 PM
I have used them on my mt. bike and liked them for the most part. They equal about 40 to 45 psi, which is good for your average climbs and cross country, but added a noticeable weight gain. I wouldn't want them on my dirt bike. I'll stick with the heavy duty tubes. :banghead:
  • ARin
Posted October 26, 2005 - 07:35 PM
They also wear out and start to powder after a few hundred miles.
  • rushfan
Posted October 26, 2005 - 07:43 PM
I've never heard that but, I'll believe you since you're holding that gun... :banghead:
  • ARin
Posted October 26, 2005 - 08:32 PM
They are great for a one time enduro race...when you absolutely cant afford a flat...but for regular trail riding, they dont last long enough, cost too much, too hard to install.
  • ARin
Posted October 26, 2005 - 08:35 PM
Here are some quotes from the bib mousse tube product description:
Bib-Mousse is designed for off-road racing use with Michelin and BFGoodrich® tyres. Marked NHS (not for road use), it should never be used on paved roads. Its use with other brands of tyres is also not advised.
Each Bib-Mousse comes with a tube of mounting gel
# Bib-Mousse should not be stored for long periods at temperatures higher than 30°C
# The maximum useful life of a Bib-Mousse is six months from the date of installation on the motorcycle. This period could be significantly reduced in cases of intense use. For example, the useful life will be much shorter for motocross applications than in enduro use.
# When new, Bib-Mousse simulates air pressure equivalent to 0.9 bar. This pressure will decrease gradually over the life of the product. Replace the Bib-Mousse when it becomes too soft for safe riding.
# At the beginning of each ride, take care to bring the tyre and Bib-Mousse up to operating temperature gradually.
  • WGP
Posted October 27, 2005 - 06:34 AM
You may want to run 16 psi front and 14-15psi rear to avoid pinch flats.
Any lower :banghead:
  • mtrablue
Posted October 27, 2005 - 07:15 AM
pick up a pair of bridgestone ultra heavy duty tubes. if you've never seen them, you'll be blown away by how thick they are.
  • Husky_Forever
Posted October 27, 2005 - 08:36 AM
I've raced with both Bibs and moose and Bridgestone HD tubes. For 250's and below, the rear Bib works good. For 450's and above stick to tubes on rear. Bibs can and will melt with open bikes on the rear wheel. Up front, Bibs work good because you can hit just about anything and not get a flat.
I have used HD Moose or Bridgestone tubes for years with Slime. I run 18lbs front and 18 lbs rear. No flats in over a decade of riding that pressure. Riding area is mostly desert and Baja only. Haven't ridden much lately due to broken bones, but that is the set up I use when do.
You might look at Tire Balls too. They hold up good (except again in anything from 450 cc ups on rear tires) and can work for many tires, over and over again. I've run them as part of a race quad team for the 04 Baja 500 (Yamaha 660 Raptor with Mike Penland and Fatrob in Sportsman Class, 1st overall in class) and we didn't get a flat at all for the entire 470 mile course.
Steny :banghead:
  • WGP
Posted October 27, 2005 - 09:15 AM
18 lbs :banghead:
I'll have to try that, are you still getting good traction at the psi?
  • NJONES
Posted October 27, 2005 - 11:20 AM
Thanks for all the input. I might put one in the front and continue using hd tubes and a good hard terrian rear tire.
  • simon@vic
Posted October 27, 2005 - 03:23 PM
dont even use one it the front. it will be a waist of time!!!
  • billygoat
Posted October 27, 2005 - 08:32 PM
My experience was actually good having run them in ISDE qualifiers on my WR250f and then leaving them on my bike after that. My tires actually lasted longer. I suspect because they got better traction and I spun the wheel less. They were difficult to install at first, but get the zip-ty levers and wedge that wheel against the garage door jamb and it works fine with one person. Lube is essential. After I used up the lube that was supplied, I used axle bearing grease with no problem.
After they wore out, I cut them up into trophy parts. I cut up a worn out tire with the mousse inside. They mount to a trophy plaque for a unique trophy. Not a real good reason to buy them though. Cost me $350 bucks for the pair.
  • billygoat
Posted October 27, 2005 - 08:33 PM
I take the $350 statement back. Maybe it was $180 ( I think I bought michelin tires at the same time).
  • mtrablue
Posted October 28, 2005 - 05:55 AM
I've raced with both Bibs and moose and Bridgestone HD tubes. .
Steny :banghead:
not just heavy duty, the ultra heavy duty.
  • ncmountainman
Posted October 28, 2005 - 05:56 AM
the bridgestone UHD's are about pinch proof,i've run down to 10f/8r psi on some slimy rocky stuff without problem. the really neat thing about the UHD's is you can take the knobby off and just run the tube@ 30 psi for super-moto :banghead:
  • billygoat
Posted October 28, 2005 - 10:34 PM
UHD's sound thicker than most mountain bike tires. Gotta like that.
