Need for Speed?
10 replies to this topic
  • wcironboy27
Posted October 25, 2005 - 10:17 PM
Does anyone know what the top speed for the XR650R is... or there abouts?
  • BWB63
Posted October 26, 2005 - 04:03 AM
Uncorked -> stock is 99.7mph
http://xr650r.borynack.com/
  • BlueBayou
Posted October 26, 2005 - 12:31 PM
I was right around 90 truly stock-> still corked
but nobody leaves them that way.
  • wr450fyamaha
Posted October 26, 2005 - 05:37 PM
90 ish
  • TimBrp
Posted October 27, 2005 - 02:51 AM
90 ish
This must be from all the scientific testing you've done, huh? How the hell would you know....coughpostwhorecough...
  • BWB63
Posted October 27, 2005 - 04:03 AM
wr450fyamaha??? Who is he? I don't see a "wr450fyamaha" Join those that use the ignore option and he is gone!
  • TimBrp
Posted October 27, 2005 - 04:51 AM
Just did it. I've been hesistant to ignore anybody because you never know if someone has something positive to add no matter what. He has totally removed all doubt.
  • wr450fyamaha
Posted October 27, 2005 - 05:51 PM
yes sir, scientific process.
  • al_piv
Posted October 28, 2005 - 05:33 AM
Another question, what gearing have others used --
  • BWB63
Posted October 28, 2005 - 02:13 PM
It depends on the rider (how far, or close to the limit does the rider ride)
What setup is the bike at (Horsepower/torque)
Where and what type of riding?
High speed gearing 15/47 Is great on the freeway and open desert. Stock - uncorked bike can pull about 100 mph and runs out of horsepower to go any faster. Add a header muffler and you can pull 102mph, trick the bike out and go 680cc, cam, caruretor........ect, ect,ect and you can get 118 a little more with a rev box. Astock bike put's out 44hp to the rear wheel and that is enough horsepower to push 500 pounds about 102mph +/- the bike falls off at 8,200rpm to about 39hp but, with a header muffler you can keep the horsepower to 41 (maybe a little more). So, top speed will be a give and take on horsepower and gearing with our bike. Peak horsepower is at 5,800~6,200 rpm. Higher gearing lets you use more of the peak horse power longer but, you will still run out of horsepower on a stock bike before you will ever get to the rev limiter. On a 680cc tricked out setup the peak horsepower last a lot longer, almost to 8,000rpm (58+hp to the rear wheel) so, you can get to the rev limiter and get to 118+mph. 15/47 will keep your RPm much lower on the freeway at 80mph :banghead:
15/49 is the best all around for desert riding if your bike can pull it in the tight stuff.
14/48 is the best all around gearing for a stock bike, not the best for the freeway. 102 mph with a bigger then stock (Taller like the IRC M5B) in the dirt if the bike can pull it. 97.7 stock
13/48 or 13/49 for real tight single track and rocks.
Speed Calculator, Click Here: :banghead:
  • Supplicate
Posted October 29, 2005 - 07:55 AM
With stock gearing, uncorked, Barnum's Pro exhaust, and a heavy right wrist, I had (until the batteries went dead) a recorded speed on my GPS of 109.9 MPH.
Now, that was a very rare day, it was cold, the air was dense, and this bike had more power then I had ever felt before. I just hit it perfect.
Most days it will hit ~ 95mph and just hold there no matter what.
can't wait to get all the new stuff that came in the mail while I was gone put on it and try it again here soon...
edit:
these speeds were done on established oilfield dirt roads, graded nice so there weren't too many holes or anything to mess with it.
