Exhaust Burning Fender YZ426
8 replies to this topic
  • jmckinney
Posted October 25, 2005 - 03:47 PM
I just replaced the stock exhaust pipe with a Whitbrothers Exhaust pipe on my 2000 YZ426. After a hard day of riding my fender was burned. Do any of you now if this is normal or is my jetting off. Thanks for the help Joey
  • SBRacing
Posted October 25, 2005 - 04:56 PM
check your jetting you have to be running lean....
  • phat_450f
Posted October 25, 2005 - 04:57 PM
how close is it to your fender.
  • fixxor
Posted October 25, 2005 - 05:55 PM
I have this heatshield stuff on the inside of mine, was on there when i bought it...
Pic 1
Pic 2
Pic 3
  • 00YZ426FMRCD
Posted October 25, 2005 - 08:03 PM
Did your stock pipe ever burn your fender? If not it could be either the Jetting or the diameter of the pipe is maybe a little bigger. One last possibility is maybe the newer pipe isn't packed correctly...
  • sjwr450
Posted October 25, 2005 - 08:44 PM
I'm assuming you have the White Bros with the plates? And it is burned out towards the end? I think those are a bad design. Every fender I have ever seen with that exhaust is burned.
  • Ga426owner
Posted October 26, 2005 - 12:35 PM
If it is the Eseries silencer with the plates - WB & Dennis Kirk sells a heat diffuser for this WB pipe that will keep the fender from getting scorched - I had one on my 02 WR426 :banghead:
  • teamtoxic
Posted October 26, 2005 - 03:02 PM
Buy a roll of aluminum tape. Cut a piece off about 6 inches long and wrap it around the fender edge where the exhaust is burning it.
I know what you're talking about, I had a YZ426F with White Bros. E-Series exhaust and this solved my problem. My fender didn't get burn or discolor due to the exhaust in the 4 years I rode it.
If you check out "My Garage" I have a pic of the old 426 that shows what I'm talking about very clearly.
- Nick
  • 150 Fuelie
Posted October 27, 2005 - 09:52 AM
I did the same thing as teamtoxic. People forget that the e-series shoots the exaust out of the discs not staright out the back. Lean or rich you will burn the fender.
  • Hot  113 replies
  • Hot  38 replies
  • Hot  50 replies
  • 0 replies
