DR-Z 400S Coolant
2 replies to this topic
  • rcerick
Posted October 24, 2005 - 03:02 AM
Just bought a 2003 DR-Z 400S with 2,000 miles. It has had two factory services. I'll be keeping it in an unheated garage in very cold (down to 0 degrees) conditions. Does anyone know whether Suzuki fills the coolant system with anti-freeze at the factory? Any other suggestions for cold weather storage? Thanks.
Rich C.
Posted October 24, 2005 - 08:24 AM
Say, you are a newbie, aren't you?
You'll get better results at the DRZ Forum , and probably less needling, too. :banghead:
  • StreetbikePimp
Posted October 24, 2005 - 12:06 PM
Just drain it and refill it with 50/50 mix. That way you know for sure. Doesn't take that long, and you need to do other winter storage tasks as well.
1) Change oil
2) Remove battery and store in a warm, dry place.
3) Squirt a teaspoon of oil into your spark plug hole. Crank the motor over to coat the inside of your cylinder.
  • 5 replies
  • 0 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  33 replies
  • Hot  79 replies
