breaking in new 05 yz450?
9 replies to this topic
  • tiggerda1
Posted October 24, 2005 - 02:49 AM
i just bought a 2005 yz450. i've been told to take it easy for 3 tanks of fuel but the manual says just over an hour. is an hour good enough??
  • Anssi
Posted October 24, 2005 - 03:45 AM
Once it's warmed up, you can pretty much gun it. Just do the first ride somewhere you don't have to put a big load on the engine (like in sand).
  • BergArabia
Posted October 24, 2005 - 07:48 AM
I broke in my 05 YZ450 a couple of months ago..
rode gentle for an hour..
Changed oil and filter.
A few bits of metal on the filter..
Rode a little harder for acouple of hours and did the change again..
Filter clean second time.
Changing oil and filter every 4-5 hours now. Using Mobile no.1 4T motorcycle racing oil..
Not sure if this is perfect and if i am erring I hope it is on the side of caution..
I figure oil is cheap. Gone through 3 oem paepr filters in about 15 hours of riding and now I have a stainless steel filter so I can clean it every time I oil change without a big cost..
I clean the air filter evry couple of hours.
But I am probably even greener than you are.. :banghead:
  • Doug997
Posted October 26, 2005 - 03:33 PM
Break it in as the manual instructs. Always make sure that you change your oil ofter. This will always keep a four stroke running forever.
  • sjwr450
Posted October 26, 2005 - 04:31 PM
Man I rode the crap out of mine.
  • muddza
Posted October 26, 2005 - 04:35 PM
Yeah I went easy on mine for the first 2 tanks and couldn't hold out on it any longer, did change the oil and filter quite frequently to begin with, maybee even a little more than I should have.....
Posted October 26, 2005 - 04:42 PM
Warm it up well. Shut it down, check the oil level, and look for any problems. Ride it no harder than 50-60% for the first 10 minutes or so, but don't baby it. Run it at up to 75-80% for the next hour, and then almost as you normally would after that, avoiding only lugging it or over revving. Also, acceleration/deceleration is better for it than extended periods at speed. After 3 hours change the oil, clean or replace the filter, and you're done.
The key is to avoid being too easy on it without thrashing it either.
  • ncmountainman
Posted October 27, 2005 - 06:52 AM
i agree gray,babying any new engine in and around the same rpm's for break in can be worse than just hammmering it. :banghead:
Posted October 27, 2005 - 07:35 AM
Break-in poses a problem based on a conflict of needs. The rings need to be put under a good deal of pressure to develop a good seal against the cylinder, while the piston, bearings and cams, etc., would really be just as happy to spin in a supply of warm oil for 12 hours with no load at all.
It's a kind of balancing at, in a way. Push the rings hard enough without hurting anything else. Just remember, it's a high performance engine, built for this kind of stuff...it can take it.
  • EastBayThumper
Posted November 14, 2005 - 02:06 PM
I let mine warm up and then let her rip.. You only have a 30 day warranty better make sure if something is going to go wrong it goes wrong right away. I've put about 5 to 6 hours on my new bike. What service do I need to have done to my thumper besides the oil change.. The dealer where I bought the bike wants to charge $120 just for the after-break in checkups.
  • Hot  36 replies
  • Hot  47 replies
  • Hot  38 replies
