Brighter WR headlight, (pics)
8 replies to this topic
  • ARin
Posted October 23, 2005 - 10:46 PM
I just installed a GE nighthawk H4 headlight on my wr. GE claims it is 33% brighter than OEM lights...I purchased a set of these headlights, (9003 type) at walmart for 25 bucks or so.
Here are the pics....the nighthawk is significantly WHITER than the standard headlight...and much brighter. The difference is much more impressive than the pictures suggest.
Standard headlight.
Nighthawk headlight
  • Matty05
Posted October 24, 2005 - 03:00 AM
Nice change!
My headlight is crappy, I'm thinking about going to a polisport twin headlight set up.
  • ETP
Posted October 24, 2005 - 06:01 AM
Thanks for the info ARin. What is the wattage of the new bulb?
My 03 AC electrical system can't handle much more than the stock 55 watt bulb.
  • 5valve
Posted October 24, 2005 - 12:40 PM
keeps the same wattage, but some filters and gasses are used, to project diffrent specter of white
must consider, that increased % of brightness while keeping the power consumption same, means lower bulb life
on the other hand, bulbs like philips blue vision keep bulb life at the max and improve visibility a bit, especially in bad weather..rain, fog..distant roadsigns
  • Just034
Posted October 24, 2005 - 06:34 PM
ARin, you gotta stop making all these improvements I am havinga hard time keeping up. I know, I know I just can't help myself.
  • gobigblue
Posted October 24, 2005 - 09:01 PM
did the new light replace the OEM one in the original number plate housing? mine is shattered and needs replacing
  • ARin
Posted October 24, 2005 - 10:20 PM
No, only replaces the bulb. not the glass housing.
  • bigdrtrdr
Posted October 25, 2005 - 07:42 AM
I just posted a while back about installing a PIAA 80/80 Super White.
It is a more expensive bulb. But I think it throws a ton more light out than my stocker.
  • joshbeene
Posted October 25, 2005 - 09:50 AM
I am using the UFO Twin 35 watt headlights and I love them. One is a flood light and the other is a pencil beam. I used them down in Baja a lot at high speeds and I was very happy. Not to mention you can get replacement bulbs at Home Depot for 5 bucks. You can even get the 50 watt bulbs at Home depot and run them if you want. The bulbs from home depot have a different taper to them so you have to put a little high temp gasket maker to hold them from shaking. You can run this with the stock stater also!!
