Oil choice vs Heat
10 replies to this topic
  • Cosmo
Posted October 23, 2005 - 12:58 PM
I ride a 99' XR600. Stock motor with an FMF pipe. I'm wanting to keep the temp. down in the motor.Any oil suggestions? Has anyone tried the 2cool advertised here on TT? I use the bike for Baja,etc.
  • rmhrc630
Posted October 23, 2005 - 02:07 PM
Big ass oil cooler is the trick - like what Johnny C used to use in baja
  • goblin127
Posted October 23, 2005 - 02:14 PM
Obviously the synthetic would be the way to go.
  • RingKingPin
Posted October 23, 2005 - 04:12 PM
Yup, that way you can find the leaks AND blow the muffler bearing!
  • wr450fyamaha
Posted October 23, 2005 - 06:25 PM
dude, just run 10/40.
  • Shawn_Mc
Posted October 23, 2005 - 06:49 PM
20-50 Mobile1 synthetic. Its amazingly resistant to heat and the trans works nicely on it too.
An oil cooler is definitely a good idea.
  • rmhrc630
Posted October 23, 2005 - 09:49 PM
yeah I got an Setrab version from precision concepts - man this thing is massive but the lines themselves add like a quart of oil capacity.!!!
  • LotsOfBikes
Posted October 23, 2005 - 09:50 PM
If you are concerend about oil heat, install all of the plumbing and cooler from an XR400R. I've seen this done. It is not hard at all.
  • TimBrp
Posted October 24, 2005 - 06:15 AM
Stay away from anything listed with MOLY in it. Not friendly on your clutch. Best bet would be a semi synthetic blend in a 20w-50. Spectro makes a great oil and you can get the same from Honda too.
  • BRP-rider
Posted October 24, 2005 - 07:25 AM
I run 20w-50. :banghead:
  • Phuzzy McPhuzzface
Posted October 24, 2005 - 07:32 AM
Ditto.
20W-50 here in Texas.
Change it often. :banghead:
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 9 replies
  • Hot  186 replies
  • 3 replies
  • Hot  60 replies
