I've been having a heck of a time with the running of my bike lately. It's getting a little colder but i'm having to use choke now to start the bike, unless i want to crank it for a little bit without. I've developed a hesitation/lean spot off the bottom, although it smells rich from the pipe. When cold it is not very driveable and even when warm it isn't perfect with a little stumble off the bottom. I'm thinking that i may have a clog somewhere and i'll probably be doing a session with some carb clean and compressed air. i checked for leaks, none to be found. the carb still responds to the fuel mixture screw. Some other symptoms are 5mph less up top as well as a powerband that has spikes in a few places. also, it likes the dynojet 170 main the best which makes me think i have a lean condition somewhere in the circuits and i'm covering it up by using the really big jet for the stock exhaust. plugs look ok with the big jet but with the dj160 they are lean.
Any of you guys have any similar experiences?
Just got done readjusting the valves back to the tight side of the range and the bike sounds and feels smoother because of it. Also drilled the slide and it does make a difference in how the bike runs, it picks up quicker for sure.
