too much oil
7 replies to this topic
  • skwerlee
Posted October 22, 2005 - 07:38 PM
i just did an oil & filter change on my 2000 yz426f...my buddy that i bought the bike from told me it holds two quarts, so thats how much i added. According to what I've read here it seems i may have added too much oil. will this damage anything? I've only ran it for a couple of minutes just to cycle the oil to check the level. any input would be appreciated.
  • ThrakenH04
Posted October 22, 2005 - 08:24 PM
way too much, try 1.2quarts with oil filter. And yes it does do something, ever heard of rings going bad? this would be one of the reasons why. plus it puts strain on certain parts too.
Posted October 22, 2005 - 08:27 PM
At that amount of oil, a 426 will start forcing the excess back into the engine through the line that balances pressure between the tank and the cam box. It would be best to drain off 250cc or so at the frame drain plug. Bear in mind, it won't take long.
  • skwerlee
Posted October 22, 2005 - 10:44 PM
yeah i figured i would need to drain it so that it's at the correct level. i just want to know if running it easily for the 3 or 4 minutes that i allready did is enough to cause damage?
  • joe_power
Posted October 23, 2005 - 03:09 AM
Also it will increase the pressure in the lower half of the engine, thus forcing oil past the oil seals , making a fine mess
Make bad rings? no .it will carbon up your top end real quick
  • sirthumpalot
Posted October 23, 2005 - 03:28 AM
OK I'm going from memory here.. 1.5L without filter change, 1.6L with filter change on the 426. At 2-qt you're over filled, but not by a huge amount. I wouldn't ride the track with that much oil, but you didn't hurt anything running it for a few minutes.
  • Satch0922
Posted October 23, 2005 - 05:38 AM
Total oil quantity: 1.7L or 1.8 US qt
Periodic oil change : 1.5L or 1.59 US qt
With oil filter change/cleaning : 1.6L or 1.69 US qt
  • skwerlee
Posted October 23, 2005 - 08:31 AM
cool, thanks for the info. i'm just glad that i didn't mess anything up.
  • Hot  36 replies
  • 5 replies
  • Hot  30 replies
  • Hot  113 replies
  • 10 replies
