Is too much OK
8 replies to this topic
  • blooozboy
Posted October 22, 2005 - 06:49 AM
I have too much oil in my WR426 it is over max mark is this a problem??
  • clark4131
Posted October 22, 2005 - 08:23 AM
Yep, drain it back down to within the operating range. Better safe than sorry...SC
  • minion
Posted October 22, 2005 - 09:20 AM
The reason too much is bad, is because the gears, etc in the oil are supposed to just slightly dip in the oil. Having extra oil in there submerges some parts which are not supposed to be submerged, and when they move, it creates a greater tendency for the oil to foam up. If the oil foams, it doesn't do a very good job of lubricating the parts. Thats one reason why you'll see some oil manufacturers say low-foam formula on their bottles.
M.
  • FTD
Posted October 22, 2005 - 10:48 AM
From the amount of oil mine blows onto the skid plate... I would think it would blow out any minimal excess. :banghead:
  • blooozboy
Posted October 22, 2005 - 01:21 PM
Cheers boys I will drain a little out wouldnt want foamy gears
  • byggd
Posted October 23, 2005 - 03:53 AM
M.
I thought the wr had a dry sump system :banghead:
  • 5valve
Posted October 23, 2005 - 04:18 AM
dry sump it is...no gears overflooding can occur
if too much oil, it should spurt out through the breather tube, but its a mess, till level corrects itself
if you go for manual drain, be sure to warm up the bike completely, so that the correct level is shown on the stick - you dont want to suck out too much
  • minion
Posted October 23, 2005 - 08:32 AM
I didn't even think about the dry-sump setup. Woops. :banghead:
I'm used to those "other" bikes that don't have dry sumps. :banghead:
M.
  • blooozboy
Posted October 23, 2005 - 02:55 PM
Thanks,Level over top of max but no leakage.
To check I warmed up bike for a few mins then turned her off left her a minute and then dipped without screwing in dip stick and it read over top mark.
I have riden since and there does not seem to be any leakage anywhere.MAYBE I DID IT WRONG.
What do I do now "To drain or not to drain that is the question"
