Hard starting! Help!!
3 replies to this topic
  • solaidrider667
Posted October 21, 2005 - 08:15 PM
Ok my Yamaha Gods-- I have a 2000 yz 426 , has been running great, lately when starting for first ride I must push start it. (yes very hard)
I have ridden it very hard last two years on supermoto tracks- oil changed every race weekend(Motul 10/40 full synthetic) air filter etc. By the way this bike has taken a 245lb rider to a 2nd in points Starrs Supertt class and current 2nd place in points. The only track it lacks power is Willow Springs.
I have not checked the valves(ever) BAD BAD ME!! I am also curious about a key that comes loose on the crank? I am considering a big bore kit and hot cams.. what about the bottom end? Thanks in anticipation for your help.
:banghead: :banghead: :lol: :busted:
  • Yak
Posted October 21, 2005 - 08:52 PM
First things first....
Change your plug... NGK CR8E
A fouled plug will make starting hard every time, sometimes even impossible.
if not that...
Time to check the valves. Actually, time to check the valves anyway. Just do it.
  • FlashGordon
Posted October 21, 2005 - 09:03 PM
Check your valves. If they are OK, clean the carb, and consider richening the pilot jet, or turn the fuel screw on the bottom/front of the carb bowl out a couple turns. I found that going up one pilot jet size made a world of difference in starting, and eliminates the popping on de-acceleration. My 400 will start on 2-4 kicks when cold, and 1st kick every time when hot. It was a killer with a stock pilot.
  • PumpkinHumper
Posted October 22, 2005 - 05:18 AM
You have tight valves. That is what is causing your hard starting. Check the valves.
  • Hot  36 replies
  • Hot  28 replies
  • 10 replies
  • On January 15, 2017
