where does that whiff of antifreeze come from?
6 replies to this topic
  • Zapp22
Posted October 21, 2005 - 06:59 AM
gang
01 BRP... where does the smell of antifreeze come from? I"m not losing much... takes a long time to hit a point where I need to add... no obvious drip, but I always smell it.
This is the ONLY thing the BRP has in common with my little DRZ400E....[well, and they both have two laced wheels]
thx
z
  • JackAttack
Posted October 21, 2005 - 07:36 AM
If your bike is not uncorked, it is going to run hot.
It takes very little coolant overflow to make a big stink. It probably goes into your overflow tank, whiff, and then gets sucked back into the rads when the bike cools.
:banghead:
  • Zapp22
Posted October 21, 2005 - 06:06 PM
nope, I'm talking about cold start, first fireup on an UNcorked bike
z
  • cholwerk
Posted October 21, 2005 - 09:09 PM
Leaking Head Gasket.
  • J_Daniels
Posted October 21, 2005 - 09:36 PM
There is a dye you can buy from the auto parts store, leaks show up under a black light. It would certainly be worth a try if you can't find the cause by wetness or residue build up.
  • Old_Man_Time
Posted October 22, 2005 - 05:50 AM
I suppose you have dealt with the obvious. Tightened all your hose clamps made sure the thermostat housing isn't leaking and installed a 1.6 or 1.8 radiator cap. Kawasaki makes the 1.6 radiator caps for the KX500 as an option and they fit the XR650R perfectly. Don't even keep that worthless 1.1 stock cap.
  • babbs
Posted October 22, 2005 - 08:47 AM
Head gasket
  • Hot  60 replies
  • Hot  35 replies
  • 9 replies
  • Hot  29 replies
