Shawn_Mc said:
If you do very much high speed braking, the cover will allow the thing to boil the brake fluid in the caliper and warp the hell out of the rotor.
Huh?
If brake fliud in a dirt bike is boiling, you've got other problems...like your bike is on fire.
Boiling brake fliud doesn't warp rotors, it just ends up being a gas when you need a fluid, and that's bad for hydraulic devices since they no longer function as designed. The rotor may warp due to uneven heating/cooling from riding the brakes, etc.
Quote
If its super muddy they can help, other than that...just a nuisance
x2. :thumbsup:
The one on my 250R won't protect from a great impact, but it does keep mud off the brake assembly. Many times the cover is coated in mud, but the rotor/caliper stays relatively clean.
