set up question's
2 replies to this topic
  • 228jeff
Posted October 17, 2005 - 06:42 PM
Does anyone know if a Canadian 2003 WR 450 has the grey wire and if so where do I find it.
I just installed a JD jetting kit.
I used the blue needle three down from the top and a 165 main jet with a 48 pilot jet.The air screw is turned out 2.5 turns. We are at around 400feet above sea level and the temperature is about 45-55 degrees. I haven't had a chance to test ride the bike yet but while in the shop I heated it up and it seemed to run very well except it had the dredded bog/stall when cracked open from idle. This is what I'm trying to get away from. I have a Hindle competition exhaust and YZ exhaust cam.
  • Indy_WR450
Posted October 17, 2005 - 07:09 PM
Take your leak jet and solder it shut. Move the red needle to clip #4 or 5 and put in a 170 main jet. :banghead:
  • Bamster
Posted October 18, 2005 - 04:27 AM
No grey wire, no throttle stop on Canadian models.
They know where the real men live. lol. :banghead:
The 05's are the same in both the US and Canada now.
