High Compression Piston Kit...
3 replies to this topic
  • Skyrat
Posted 17 October 2005 - 03:48 PM
Just wondering if anyone has installed the Keintech high compression piston kit or an equivalent in a DR650? I have been wondering if installing it would seriously hamper the reliability of the engine? Does it do much to improve the output of the motor? Does premium gas have to be used? Any and all feedback would be appreciated.
  • brianwheelies
Posted 17 October 2005 - 05:15 PM
No experience with his particular kit, but i've read you need to run premium. I put a wiseco hi-comp piston in my old 350 before eventually doing the big bore and it seemed to give it more snap throughout though. I think it says on his site that it gives a few hp as well(nothing wrong with that). These motors are pretty stout, i regularly top mine out for several miles and she holds together quite well.
  • Mudshark
Posted 17 October 2005 - 07:21 PM
They used to run at a slightly higher compression back in '93 / '94
See specs below according to the Suzuki web.
Back then they produced a few extra horses as well.... so it's problably
not a bad thing to do.
DR 650 R 1993
Overall Length: 2 385 mm (93.9 in)
Overall Width: 870 mm (34.3 in)
Overall Height: 1 330 mm (52.4 in)
Seat Height: 890 mm (34.8 in)
Wheelbase: 1 505 mm (59.3 in)
Ground Clearance: 245 mm (9.6 in)
Dry weight: 166 kg (365 lbs)
Engine type: Air-cooled 640 cc single cylinder
4-stroke. OHC, SACS.
Compression ratio: 9.7 :146 hp (33,6 kW)/ 6.800 rpm,
56,6 Nm (5,77 kg-m)/ 5.000 rpm.
DR 650 SE 1996
Overall Length: 2 255 mm (88.8 in)
Overall Width: 865 mm (34.1 in)
Overall Height: 1 205 mm (47.4 in)
Seat Height: 885 mm (34.8 in)
Wheelbase: 1 490 mm (58.7 in)
Ground Clearance: 265 mm (10.4 in)
Dry weight: 147 kg (324 lbs)
Engine type: Air/oil-cooled 644 cc single cylinder,
SOHC, 4 valves.
Compression ratio: 9.5 :143 hp (32 kW)/ 6.400 rpm,
54 Nm/ 4.600 rpm.
  • dataturtle
Posted 18 October 2005 - 02:53 AM
I am thinking on changing carburator, put in a better camshaft and high compression piston kit. I haven't decided yet if I want to do that or change bike :-)
I would really like some extra hp in the low end.
I also want to point out that if you do something like this you need to service your engine more often, then it should not be any problems to make it last. Change oil et cetera.
