I've got a 86 xr600r. has been idle for 6 yrs. less than 5000 mi. or so. i had it in az. for the desert, now i'am in wi. i have been getting it back in shape and have it licensed. it still has all kinds of power. dual 28mm carbs. i opened up the air box, had it re-jetted . wraped the headers to keep it a little cooler and took out the arrestor. aside from that it is stock. i plan on keeping this bike forever and ever, something fun to work on. the next thing i would like is exhuast, any suggestions? eventually i would like to bore it maybe even high comp. piston. but i almost go flying when it kicks back as it is, i only weigh 150 lbs. it scares me to think how it would be with engine mods. any suggestions? :eek:
86 xr600r
Started by timothypg, Oct 17 2005 01:30 PM
9 replies to this topic
Posted 17 October 2005 - 01:30 PM
Posted 17 October 2005 - 02:00 PM
Getting pipes for these older XR's getting tough. Ive only found one place that even entertained it without having to give them the bike. XR'sOnly can get it done.
They'll do a full motor for you too, big 630 kits and kinds of stuff...
Id like to be able to ditch the dual carbs but I cant see how a single carb manifold would work in the stock frame, even if you figured out the air box boot. One runner would have to be way longer than the other. If anyone has any insight to this, Im all ears...
Posted 17 October 2005 - 02:11 PM
Getting a pipe shouldn't be hard.The same pipe fits all these years, Honda XR600 '85-87/'91-98/'00 . FMF still has one in their catalog.
Posted 17 October 2005 - 05:04 PM
Posted 18 October 2005 - 02:02 AM
I would keep the dual carbs, get them working right and enjoy their benefits. There is no real advantage with the single carb except it is easier to remove and rejet. The single carb isn't perfect, it has a DODGY choke butterfly that should be scrapped as a rule, and a sticky throttle action from fully closed for which there is no known cure.
Posted 18 October 2005 - 08:37 AM
IF I was to swap the carb, I would put a CV or the stock style single. Id put an FCR-mx on there for two reasons.
I can get them off ebay pretty easily
And I know them like the back of my hand...
Posted 18 October 2005 - 08:59 AM
Shawn_Mc said:
IF I was to swap the carb, I would put a CV ...
Yer trippin. CV Carbs are junk
Posted 18 October 2005 - 10:57 AM
I've got the carbs working about as good as can be. would love to have pumpers but that would cost a pretty good amount of cha-ching, that is if i could get them synchronized and all that. for exhaust xr's only has one, w/b e2,fmf titanium 4, pro circuit t-4 do you think that one of these stands out from the rest? i don't mean to have you guy's do my shopping for me, but if you have an opinion on any of the mod's i would like to do i would like to hear them. thanks
Posted 18 October 2005 - 11:14 AM
Not trippin, full on typeO
Should say wouldnt, not would... :excuseme:
Posted 22 October 2005 - 01:04 PM
i had the shop re-jet the carbs up one size, clean the carbs and stuff. it ran great. or so i thought. i went and got the next size up, 125. put them in. NOW it runs great. the air/fuel is still only open a little less than one turn. maybe even bigger jets? how big do you think i dare go. :thumbsup:
