Hi i have a tinking noise coming from the top end of the engine. the engine has only done 100mi and i have set the valve clearances (actually i checked them they were within tolerance so i didnt have to adjust). i was wondering if the camchain tensioner is sticking allowing the camchain to get loose. the bike did spend 3 months at sea getting to Ghana.
is there an easy way to check this or is this tinking noise normal. i have no other XR650R in area to compare. apart from this engine is running fine
thanks
