Hi,
When adjusting the valves on my XR650R I do the rights thing and rotate the flywheel counter clockwise etc to ensure the auto decomp isn't engaging, but I was also told I MUST do the following:
"You need to be sure that the manual decompression lever is not actually trying to open the exhaust valve while you are setting the valve clearances. The easy way to ensure that this is not happening is to remove the cable either at the rocker cover or at the decomp lever on the bars. You would be surprised at the number of people I have come across with XRs who set the valves incorrectly by not thinking about the manual decomp lever."
I have never done this - is this guy right?
Scoobie
