06 WR450 suspension
5 replies to this topic
  • Jim_bo
Posted October 16, 2005 - 07:01 AM
I checked the race tech website. For a 200lb rider, the forks spring rates are right on. However, the shock spring rate is 5.3 stock and 5.52 recommended.
Do you 05 & 06 WR450 riders think the stock shock is too soft? Have any of you replaced it? What were the results? Did you have to revalve?
Jimbo
  • Farmer Hank
Posted October 16, 2005 - 07:45 AM
At 210 lbs. I needed to upgrade to a 5.6 spring to get proper sag. I found that this allowed me to back off the hs compression to 1 3/8 or 1 1/2 turns and I ended up with a much more supple suspension. I'd sure play around with upgaded spring and adjusting the compession damping before I shelled out for revalving.
Farmer Hank
  • tony1970
Posted October 16, 2005 - 08:25 AM
I'm at 200lbs and the stock shock and spring are fine. I was able to set proper sag and it feels fine to me, in fact i had to back of the clickers because it felt stiff because I ride mostly single track.
  • Jim_bo
Posted October 16, 2005 - 10:05 AM
hhhhmmmmm..... is Race Tech off in their recommendations??
Any other opinions???
  • clark4131
Posted October 16, 2005 - 12:55 PM
Racetech's recommendations are based on their valving rather than stock. It's a good rule of thumb to go one up from what they call for. I'm 220# and run a 5.8/.48 with great results...SC
  • Jim_bo
Posted October 16, 2005 - 07:41 PM
Stock valving??
