Just bought a 1997 XR600R...any advice?
11 replies to this topic
  • kehale
Posted 14 October 2005 - 08:39 PM
This bike is new to me. i have the service manual, but don't have the owners manual.
Choke on up or down?
I'm thinking down.
Starting w/ or w/o choke doesn't seem to make much difference.
It's a 3-4 kick affair.
Any advice would be appreciated.
It seems to be a well maintained bike and is very clean (no damage, plastics are all original and in pretty good shape)
Thanks,
T
  • LVThumper
Posted 14 October 2005 - 09:03 PM
Congrats! :thumbsup: I have the same bike, and I love it! The only problem I have had with mine is I sucked the bottom part of the choke plate into the engine, which let to rebuilding the top end, TWICE!!! :foul: I had been told to check it, and replace it, with a billet one from XR's Only, but I waited too long. Other than that, the bike is great for play riding with my boys, racing through the desert, and as far as climbing hills, well John Deere turns a darker shade of green when I tractor up through some of the toughest climbs in Nelson Hills! :applause:
Enjoy! :ride:
  • BRP-rider
Posted 14 October 2005 - 09:25 PM
1990 XR600R
Hey,
I did the same thing as you.
My choke plate was sucked into my engine.
I was lucky it only banged against the spark
plug and closed the gap and so it instantly
shut off the engine. Got it home and to make
a long story short, I blew the piece out the intake
valves with compressed air and a vacume!!!
No engine damage, compression is good.
I didn't buy a new choke or carb.
I installed a primer bulb system.
Starts even easier!! :thumbsup:
  • malevolent73
Posted 14 October 2005 - 09:42 PM
so do you have any choke on it at all? or not?
  • kehale
Posted 14 October 2005 - 10:30 PM
any info on this part that comes off??
Sounds like a grenade with a loose pin!
  • BRP-rider
Posted 15 October 2005 - 07:36 AM
No choke.
I have a priming system.
Works great. :thumbsup:
  • bork
Posted 15 October 2005 - 07:41 AM
Wher to get primer bulb and easy install ? how much ?
  • bork
Posted 15 October 2005 - 07:44 AM
I'm thinking down.
Thanks,
T
Maybe choke already broke off ? usually 1-2 kicks cold with choke on . I would not ride until choke flap is verified . I got a QS carb before mine broke . My buddy , not so lucky , cost him over 2k .
  • kehale
Posted 15 October 2005 - 07:46 AM
Anybody have a pic or a diagram of this part?
I don't want to remove the wrong thing! haha :)
I've never dissassembled a carb, but I've changed the jets before in my quad.
-T
  • BRP-rider
Posted 15 October 2005 - 07:47 AM
Any local motorcycle shop should have one.
Mine I think was $20.
  • miguelitro
Posted 15 October 2005 - 08:45 AM
xrsonly.com sells em. yes do it befor it happens worth every .01
congrats on the 600 though, i really miss my old 91...sure the 02 650 is great but i had special bonds with that bike:D
where you at in CA?
  • LVThumper
Posted 15 October 2005 - 02:03 PM
Actually, when I rebult the top end, the second time, I swapped out the stock carb for a Mikuni Flat side. :thumbsup: Great throttle response and between that, proper jetting, and a stage 1 HotCam, I'm pulling 5 more ponies! :busted: :ride:
