Kickstand problem
2 replies to this topic
  • Sean_McCutcheon
Posted August 20, 2001 - 03:40 AM
I lost the bottom bolt that holds the kickstand on the bike. I have a collection of metric bolts and some reason none of them are the same size that was in it. Does anyone know the size of that bolt.
  • carverdude
Posted August 20, 2001 - 09:45 PM
I lost mine also.I do not know the size but it is a common metric thread.My new bolts came from the local hardware store.They are Loctited now!
  • BlueThunder
Posted August 20, 2001 - 10:27 AM
Those bolts are a M10 X 1.25 X 20mm. I too have replaced those guys and Loctited the replacements. No problems since then. Just out of curiousity, do you start your bike on the kickstand ? I have to and I think that the added pressure is what loosened the originals. Good luck.
Y2K WR400FM,Answer top tree w/Accu-Trax clamp,Pro-Tapers(CR-Hi w/ EE handguards),Devol Rad. & frame guards, Guts tall soft foam w/ ballistic cover, 14/52 w/DID VM X-Ring, Kouba-T,Michelin M-12's ft.& rr.,12 oz. flywheel weight, Zip-Ty Racing Link & Shark Fin, Cycra front rotor guard and T.M. Designworks Chain guide, buffer & chain wheels.
[This message has been edited by BlueThunder (edited 08-20-2001).]
